1080p Full HD Bullet Camera System
Zum Angebot: http://www.dogcamsport.co.uk/minidvr-hd ... amera.html
MiniDVR HD Bullet Camera System
Welcome to the 5th generation of MiniDVR bullet camera systems with portable digital video recorder.
The MiniDVR HD has a staggering 200% improvement in video quality when compared to its predecessor.
It can achieve full 1080p HD video from the small bullet camera and stores the video on to the recorder
using SD cards up to 32gb in size.
The camera part is fully waterproof and the recorder part is rugged and splash proof. The camera comes
with a 1.5m cable and uses a locking MiniHDMI Connector.
As soon as you turn the system on you will see a preview from the camera showing on the screen.
This allows you to position the camera perfectly before you start filming. You can also use the screen
to view back the videos you have recorded and for viewing photos you have taken with the system.
The battery will power the Mini DVR HD system for at least 3 hours record time and spare batteries
are also available if you scroll down towards the bottom of the page.
At full quality you can record about 4 hours of video on to a 16gb card and this can be expanded up
to 32gb if required.
The camera part is supplied with a range of mounts for car windscreens, handlebars and helmets.
Because the camera and the recorder parts are separate, it makes the camera one of the smallest
1080p HD imagers in the world. You will hardly even notice it's there!
Using a HDMI cable (available below) you can plug the system in to any HD television and stream
full HD video back which looks fantastic when using a high quality HD TV.
The MiniDVR HD DVR has a built-in microphone and you can also plug in an external microphone
for recording higher quality audio and for getting the mic out of the way of wind when using with
a car or bike.
Supplied as part of the kit is a wired remote controller which will let you turn on and start recording
by pressing one button. The remote flashes bright red to let you know the system is recording. An
enhanced remote controller is available below.
The video files made by the MiniDVR HD are standard HD video files using h.264 encoding. They are
compatible with just about any video editing software on the market and anyone using this system
for professional use will be happy to hear it can do 25, 30, 50 and 60fps at 720p and 25 or 30fps
in 1080p
The MiniDVR HD helmet camera has many other features such as motion detection and a car mode
in which the system will turn on and start recording video in a LOOP fashion when the memory card
is full. The enhanced remote is required for this function and is available for £14.95
A file recovery mode had been added to the system. If for any reason your video files should become
corrupt, the MiniDVR HD will try to recover them automatically.
Includes:
Mini DVR HD System
Belt Clip for DVR
AC Mains Charger (UK)
Car Charger
Wired Remote Controller
AV Cable
Vented Helmet Mount
Protective pouch
Magic Mount
Flat Surface Mount
Bar Mount
Battery
Download: MiniDVR HD Manual - Spec Sheet
These make excellent in-car cameras and on board camera systems.
Please see our blog on Rolling Shutter Effect for more info on why professionals are choosing
high definition bullet cameras for filming motorsports.
Alle Angaben vom Hersteller / Vertreiber sie Link oben.
Daher keine Gewähr für die übertragenen Angaben.
a car or bike.
in 1080p
Includes:
Mini DVR HD System
Belt Clip for DVR
Car Charger
AV Cable
Vented Helmet Mount
Protective pouch
Magic Mount
Flat Surface Mount
Bar Mount
Battery
Re: 1080p Full HD Bullet Camera System
Heyhey, habe die kamera gestern auf ebay erstanden, ich weiss, dass es für die mal eine neue firmware gab. hat da zufälligerweise jemand einen link für? ich finde sie partou nicht im netz,..
LG
LG
Aktuell ist bei http://www.dogcamsport.co.uk/mini-dvr-h ... pdate.html" onclick="window.open(this.href);return false; kein downloadlink mehr zu finden. Du musst in der Zeit zurückreisen, ins Jahr 2012 und die betreffende Webseite aufrufen.
Bevor du mich für völlig gaga hälst, mit web.archive.org ist das möglich.
Der Einfachheit halber hier gleich der direkte Link: https://web.archive.org/web/20121004182 ... pdate.html" onclick="window.open(this.href);return false;
Unter Punkt 5 findest du deine firmware als download. Der ist noch aktiv, der testweise download der Datei "hd93c.zip" 3,1MB hat funktioniert.
wow, 45 min für die perfekte Antwort!
Respekt und 1000 Dank :-)
archieve.org kenn ich, aber auf die Idee, dass auf die Suche nach der Firmware anzuwenden wär ich nicht gekommen. Allerbesten Dank :-)
Hmm, das update funktioniert aber irgendwie nicht, hab die files auf die SD und wenn ich dann neu starte, fragt er mich aber nicht nach einem update....
Irgendwelche Ideen?
Irgendwelche Ideen?
Die Datei hast du entzipppt? Es sollte sich auf einer neu formatierten SD-Karte nur "hd93c.bin" befinden.
Genauso hab ich es gemacht. Im Kameramenü zeigt mir die Kamera an dass diese Cirmware aktuell installiert ist R823/20111219
